Old 10-21-2009, 10:12 PM   #114 (permalink)
racprops
Well IF I read this correctly:
I used:
A1-INJ1 INJECTOR#1 Brown, Battery Voltage
B2-LG2 ground to shields for CYP & TDC Brown/Blk, <1V
If I read that as your on injector #1 and on the 12 postive wire, If that is right then you on the wrong wire, you want the wire that does not have 12 volts, as the 12 volts is the supply and the other wire it the trigger wire.
Try switching them.
If I read that wrong I am sorry and forget it.
Rich
