Old 10-22-2009, 01:38 PM   #12 (permalink)
janvos39
janvos39's Avatar
FKB - '03 Focus DAW/FFDA1/5PFDMW
90 day: 45.7 mpg (US)
I think that a primairy pipe size of max 26 mm internal should be used. This size is used on some Honda 500 -4 engines. Sufficient to support 15 HP per cylinder. The length of the primairy is longer for two into 1 muffler than when each pipe has his own muffler. This comes because the temperature is higher in the first case leading to a higher velocity for the pulses.
