Old 10-23-2009, 02:48 AM   #10 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Originally Posted by Gasoline Fumes View Post
One of the reasons I might not build a trike is the difficulty of finding a suitable transmission. With a max RPM of 2000, it's going to need multiple gears to acheive a respectable cruising speed and still be able to accelerate. I have a 3-speed lawnmower gearbox that would be OK, but it's designed for a vertical shaft engine and is grease-lubed. My other concern is MPG. I'd hate to go through the trouble of building something and then find out it gets only 61 MPG and has a top speed of 34 MPH. It would have to get about 100 MPG and go 50 MPH for me to build it.
Why such high expectations? What do you have that even comes close to rivaling that now?
Being more realistic, 61MPG on diesel which is basically free (if you make it yourself) is still a sight better than 100 MPG on $3.00 a gallon gasoline.
Average cost of BD when you make it at home, and using free WVO to make it, is about 90 cents a gallon, last I heard. At the price of the gas station next door, $2.70 a gallon for gasoline, I'd have to get 90MPG gasoline to match 30MPG diesel.
Your speed limitation isn't really all that realistic, either, I think. How many days do you really HAVE to go 50 MPH? Could you not suffice with 35-40 MPH?
Beyond that, there are many things you can do to increase the power output once you've built the project and gotten it working. Later on, you can streamline it, change gear ratios, increase output and efficiency with a small turbo, etc.
Build it, then worry about the details. Very few peopele actually stick to all of their goals when building something one-off. Compromise is necessary until the thing can be considered "tangible".
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
