Old 10-23-2009, 08:26 AM   #16 (permalink)
JasonG
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.26 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
This guy has a nice calculator that works, simple too www.rickwrench.com/bunchofcalculators.html
X pipes don't work on twins as the pulses are too far apart to mesh as they do in a V8.
The small pipe on the Ninja250 H layout is called a balance pipe. It is too small for scavenging but I can't remember if it was for noise or emissions ......
Beatr911 that link at dairally looks deep, i cant wait to try it out !
On the carb switch, 1 single carb usually gives better low end torque while separate carbs perform better at higher RPMs.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
