Old 10-23-2009, 09:21 AM   #2 (permalink)
moorecomp
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 40.5 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 24.98 mpg (US)
It looks like the vss signal is pin 66 on your PCM color is white/orange. Injector signal for cylinder #1 is pcm pin 13, color is white/dark blue. Don't cut the wires, just strip an area about a half inch long and wrap the wire going to the guino around the stripped area, solder the connection and wrap with electrical tape. I assume you will be able to find a 12v supply that is hot all the time and a good ground.
Go to the wiki: http://ecomodder.com/wiki/index.php/MPGuino for setup and calibration directions. Good luck.
moorecomp
Mancelona, MI
