Old 10-23-2009, 11:53 AM   #1 (permalink)
bennelson
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Battery heating for EV efficiency
Most hypermilers, ecomodders, and fuel-economy fans are familiar with using a block heater to improve fuel economy in a gasoline vehicle. However, drivers of electric vehicles should also know that warming your batteries in the winter can give greatly improved EV performance.
In general, my cheap-o electric car (running on used batteries) has had a range of about 20 miles in the summer, but could be as low at TEN miles in the winter!
While there is snow, increased rolling resistance, thicker transmission fluid, etc in the winter, the MAIN difference is battery temperature.
Many battery types just can't give out as much power when they are cold. A simple example of that is trying to start a gas car on a cold winter day. The starter (powered by the battery) just doesn't crank as fast and hard.
So, to keep our cold-climate EVs in top notch performance for the winter, here's a few things to try:
USE YOUR GARAGE:
If you have a garage, use it! Even though my garage is not attached to the house, isn't heated or insulated, it still keeps the wind, rain, and snow off the car. What little heat is in the car gets retained a bit better. If you have a heated garage, that's probably the ultimate way to get better winter EV performance. (Small EV's such as scooters or electric bicycles could simply be brought inside.)
OTHER SHELTER:
If you don't have a garage, at least try to park out of wind, perhaps next to a tree, which in real-world testing have been shown to act as heat storage and help prevent frost formation on the car's windows. (But watch out for pine sap!)
INSULATE YOUR BATTERIES:
Batteries will be much happier if they are wrapped in a cozy blanket. If batteries are exposed to the outside world (such as under the hood) heat can also be lost to wind. Any insulation should be water-resistant and non-conductive - using foil-faced foam is a bad idea - but using pink builder's foam works great.
WARM YOUR BATTERIES:
Find some way to get a little heat into your batteries. The best way is with something in direct contact with the batteries, either under them, or on the sides. It will need to have some sort of automatic temperature control, to prevent overheating.
Waterbed mattress heaters, electric blankets, and water-pipe freeze prevention tape all have automatic temperature controls, and can easily be repurposed to warm batteries. Make sure to not set batteries directly on heating elements. Many heaters can be easily wrecked that way.
IF YOU ARE HAPPY, YOUR BATTERIES ARE HAPPY:
While I don't mind wearing a heavy coat, hat, and gloves in the winter, it is nice to be just a bit cozier than that in my car. Last winter, I experimented with an oil-filled electric radiator space heater. I simply put it in the car (behind the passenger seat) and ran an extension cord out the window. That was plugged into a timer going to the wall. The heater came on automatically in the morning, and heated the inside of the car for about 45 minutes before I left for work. I would unplug the heater, and drive off. The heater would stay warm for about 10 minutes after that. (In my gas car, it takes 10 minutes for the engine to warm up in the winter!)
The unexpected side effect of warming the inside of the car, was that it also warmed the batteries! By trying to make myself more comfortable, I also improved the range of my battery pack!
CHARGING = HEAT:
Another trick is based on the fact that running electricity through the batteries (either discharging OR charging) warms the batteries.
Set the car's charger up on a timer so that the charge is just finishing up when you will next use the car. The batteries will be a little warmer than they would be if they simply sat charged all night. Also, opportunity charge any chance you get. Even short charges can increase your range more from the heat than from the electricity to the batteries.
I hope these tips help keep your car happy and healthy this winter! If you have any other winter electric car tips, please post them below!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
The Following 3 Users Say Thank You to bennelson For This Useful Post:
MetroMPG (10-27-2009), RacerX (11-03-2009), Rokeby (10-25-2009)
