That is looking beautiful. The LEM can handle up to 900 amps, so you should be OK. The software is really easy to change the current limit. It's like 1 line basically. Then you just need to adjust the pot on the control board. all the way to the right clockwise is 775 amps. You can change some resistor values if you want the current to be higher than that. It's not hard.
signature goes here.
