The bottom is not so well supplied with air, even with a great belly pan and rounded. 4 degrees on the belly pan is usually as conservative as 15 deg on the top and sides. If the tapers were continued to a point at the back, it should be only slightly higher than the stagnation point at the front. A bit of rake will help cancel the lift and induced drag if the air goes over the top faster than underneath.
