Originally Posted by dcb
Drive the wheels with a belt, and lever to control the tension on the belt will get you started too, via idler pully. That is how my 3.5 hp snowblower worked.
I've thought about a belt clutch, but I'm concerned about belt life if it's used too often. It's definitely the easy way.
