Old 10-27-2009, 06:54 PM   #257 (permalink)
Tygen1
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
My valve looks different because of the Coil On Plug conversion, no gain from that though.
Aluminum strut is from HD, 1" flat stock about $13 each. The skirt is Fibre Reinforced Plastic that is used for shower walls. 4x8 sheet for $27. It's flexable, cheap and can be heated and bent. It is smooth on one side and has raised bubbles on the other.
I don't think there is any question they are worth it. Just need to do some testing to prove how much they are worth.
PGRPro, are you running 135 degrees with 25:1 lean burn?
