Originally Posted by orange4boy
Yes, that could all work. You would not get much whip in a car from 5 hp but the motor would pull a lot of amps.
If the car only needs 5 hp to get up to speed. Might be a little under powered. Depends on the car, terrain, etc. Is it flat where you are?
Well, here around town, yes. The vehicle would never see any steep hills, only gently rolling roads.
I'd like to reiterate that we're literally talking about a car that weighs in right around 1,000 lbs, as well. It only takes like 25 or so HP to do 60 in my 3500# Minivan, with Cd .3 and A of 33 ish M. I just can't imagine that it would take more than about 5 HP to go around town at 25-30 MPH in a sub-1/2 ton car with frontal area of about half of the Minivan.
