Old 10-28-2009, 10:18 PM   #15 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
NeilBlanchard -
Hi folks,
Can I ask what is the intended aerodynamic function of these side skirts?
Personally, it feels a bit counterintuitive -- I would think that you want to have air "escape" out from under the car; and not to trap it under the car. And none of the ultra-low Cd cars that I am aware of have anything like this.
My (ever so flawed?) thinking is that I am separating the "clean airstream" from the "bad airstream", but I don't really know. With this mod I think I should create a "snow-plow" air dam to minimize the amount of air flowing under the car. If nothing else, in tandem with an air dam, I think this could be a form of "virtual lowering".
I did some flow simulation YouTubes and found something interesting. The imaging is a top view and is problematic, because none of the "objects" actually touch the ground, they only interfere with the air stream. I was trying to simulate the engine, transmission, suspension, and exhaust piping :
If the above is showing a valid result, then the rear ( non-moving!!! - ) tires seem to have less turbulence associated with them.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Rokeby (10-29-2009)
