I found some aluminum mesh screen, 4' wide for $2 per linear foot.
I'm not going to be putting a pan under the engine compartment, but my main concern is the rear end. I'm thinking that if I get the aluminum screen tight enough, I can get it to stay rigid against the wind, and paint it to fill in the holes, but leave it open around the exhaust.
I also found some exhaust supports I can get to replace the ones on there now. I'm planning on chopping off the current supports and tucking it up higher.
