Old 10-30-2009, 05:09 PM   #25 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Since you are looking far afield in the rebuild, I would like to suggest a couple of other things to 'get out of the way:'
  • spark plugs - they don't last forever
  • air filter - toss the old, put in a new
  • cabin air filter behind the glove compartment - they can pick up all sorts of funky stuff
  • lubricate the hydrocarbon converter linkages - use a high temperature grease
  • check belt - they almost last forever
  • change radiator coolant - you'll get the inverter coolant anyway but radiator now is a good start
  • consider 88C thermostat - I got some from Japan in January, at cost $20+shipping
  • buff out haze over headlights - easy to do now
  • measure all tread depth for all four tires - looking for abnormal wear pattern, can help on 4-wheel alignment
  • 12V DC battery - they don't last forever and there are alternatives
  • throttle plate cleaning - no so convienced about mass air flow cleaning but inspection is good
  • PVC valve - what the heck, easy enough
Local record
