The binding of a universal joint occurs at extreme angles ( like in an off-raod vehicle's driveshaft or front wheel drive axles) which is why CV joints are used in such applications. A CV joint has more bearing surfaces than a simple u-joint which usually means more friction. Does anyone have any data to support/refute this?
