Old 10-30-2009, 06:14 PM   #2531 (permalink)
squiggles
Originally Posted by MPaulHolmes View Post
Hey Ben! Basically, you have to *somehow* solder on the little 3 pronged thing. It's going to be a tight fit getting a soldering iron in there. You could insert the 3 pronged thing, then heat the metal legs of the 3 prongs, and then melt the solder that way?
Soldering tips 101.
1. It is very very important that both the surfaces to be connected are raised to the temperature that will melt the solder, this ensures a proper join.
2. You should limit the time the components are hot, particularly the pad on a PCB as heat will degrade the glue that holds the pad to the substrate.
