Old 10-30-2009, 10:15 PM   #1 (permalink)
88hf
EcoModder!
ratatouli - '01 insight
88 Crx - VTi swap
Planning to do a VX swap into my 88 crx hf. I need some help figuring out what all to get together before I order the motor. I have a vx under dash harness ( don't know if I need this) and ordered a US P07 ecu. Will this ecu work with the JDM d15b vtec-e( I think it will)? Also I am wondering whether I should source the engine from vtec-motors (canada) on ebay or nippon-motors? Should I buy new motor mounts for the old engine or the new one? I know I'll need an oxygen sensor. My hf already has an egr do I need a different control box? Do I need an obd0-obd1 harness for the ecu. I'm a little lost on the specifics that most build journals seem to skip over.
Thanks for any help.
Last edited by 88hf; 11-10-2009 at 07:45 PM.. Reason: change thread name 88 Crx - VX swap > 88 Crx - VTi swap
