Old 10-31-2009, 06:34 PM   #10 (permalink)
vpoppv
The $500 Electric Car
vpoppv's Avatar
So I finished de-ICE-ing the Corolla, which consisted of emptying the trunk. But that wasn't quite as easy as it sounds. I didn't have a trunk key. So I had to pull out the backseat, then remove some plastic barrier sheet, then move around the engine parts in the trunk to be able to take out the clip holding in the trunk lock. Once that was done, I took all the parts out of the trunk. I then discovered that there is a water leak in the trunk, and the spare tire well was completely full of water. It must have been there for a while because everything in there was really slimy. That included: a spare tire (it started floating when I pulled off the parts on it!), a jack, a tire iron, some kind of tool for the jack that looked like a wrench, and a set of snow chains. I took out a rubber grommet to drain the water. It was a perfect, warm, sunny Halloween to do it!
