Old 11-01-2009, 06:15 PM   #2539 (permalink)
drbobwoolery
49state 4door - '91 Metro 4 door
90 day: 59.31 mpg (US)
old blue - '91 Metro base CA
Paul, the optoisolator used with the shunt would also work well to isolate your voltage measurement. A 1000:1 divider with a 68 ohm output resistance would give a 200 volt full scale. You might have to put a C across the 68K part of the divider, just like tuning a scope probe. There is a spare isolator in the package with the third version of the shunt. This one uses brass closet bolts instead of salvaged starter solenoid bolts, so more can be made.
