Old 11-02-2009, 08:21 AM   #1 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Adjusting charger voltage for temperature variation (lead acid batteries)
I've been to this website before, but never really read through a lot of it. I came across this nugget this morning though. Something potentially useful for a lot of us now that we'll be seeing some colder weather.
Charging the lead-acid battery - batteryuniversity.com
Correct settings of the voltage limits are critical and range from 2.30V to 2.45V. Setting the voltage limit is a compromise. On one end, the battery wants to be fully charged to get maximum capacity and avoid sulfation on the negative plate. A continually over-saturated condition at the other end, however, would cause grid corrosion on the positive plate. It also promotes gassing, which results in venting and loss of electrolyte.
The voltage limit shifts with temperature. A higher temperature requires slightly lower voltages and vice versa. Chargers that are exposed to large temperature fluctuations should be equipped with temperature sensors to to adjust the charge voltage for optimum charge. Figure 2 compares the advantages and limitations of various peak voltage settings.
For example, I believe my Schumacher 12V charger charges my Paseo battery at 14.5V. In summer I may want that to be lowered to lengthen battery life. However, in winter, it sounds like I should kick it up a little to give me a little extra capacity. I'm honestly not sure that the Schumacher has a temp sensor, or even adjustable voltage though. If you have an EV, I'd imagine this is much more important though.
