Old 11-02-2009, 09:53 AM   #3 (permalink)
88hf
EcoModder!
ratatouli - '01 insight
List***
clutch
engine mounts (old ones dry-rotted)
cv axles (reusing hf transmission)
axle oil seals
engine seals
p07 49 state ecu (on the way)
obd0-obd1 ecu harness
water pump (is this the same on d15b vtec-e and d15z1?)
timing belt (is this the same on d15b vtec-e and d15z1?)
5-wire 02 sensor for lean burn
