Old 11-02-2009, 12:04 PM   #2 (permalink)
TomO
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 43.34 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 106.98 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
Thanks for the info Casey!
There is something similar that some people use, but we call it Seafoaming the engine.
Just a clarification for Honda owners; don't disconnect the vacuum line running to your fuel pressure regulator, doing so will bring up fuel pressure to that of WOT (Wide Open Throttle) and dump too much gasoline into your motor along with the seafoam.
The recommended way to do it (if you don't have a spray bottle to use to spray the seafoam into the Throttle body) is to use the large vacuum line running to the brake booster.
The way that I do it for my VX:
1) Remove the rubber arm from the airbox to the throttle body
2) Put seafoam (or GM Top Engine cleaner, from the dealership) into a spray bottle
3) runn motor up to operating temp and spray the cleaner into the throttle body/intake area until the full can is gone (pushing on the throttle as needed to keep the motor running during the process)
4) shut off motor and let sit for at least 15 minutes or more like 30-60 minutes
5) start up motor and fog for mosquitos for the next 5-10 minutes
6) change oil and enjoy the smoother running engine.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
