Old 03-11-2008, 06:55 PM   #15 (permalink)
dremd
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Originally Posted by extragoode View Post
I know I'm a little late to this, but I was thinking about this the other day and was wondering if one could simply change the size of the pulleys on the hydraulic power steering pump. I'm not familiar with them to know whether they work on speed or force, but I assume either halving or doubling the circumferance of the pulley would halve the power and therefore halve the load on the engine. I personally have a 4000 lb truck and it is not the easiest to steer while eocing even at speed(30mph), so I don't want to get rid of power steering completely, but I also don't need it's entire capacity.
Mmm Interesting thought.
Another idea may be to cut some off of the springs in the spool valve.
You cut a few coils off of the Rx7 spool valve (rack) when using the factory pump on swapped LsX Motors. Makes a HUGE difference in effort/ feedback, Unsure how much difference it would make on engine load. (Only seen it done on 300+++ Hp cars so load is basically invisible.
6 speed ALH TDI
