Old 11-02-2009, 06:07 PM   #15 (permalink)
AlainB7
Originally Posted by Sebastian View Post
I'm rewriting the code (based on 0.75m) for european use (L/100km etc). It may be alpha, because I can not test it because of weather atm (motorcycle..).
If someone wants to test it, I will send it to you with pleasure! Then I could correct issues if there are any.. It's also supporting a temperature sensor, if you want to use one.
I would like to test it.
How I test it? You send the code to dcb and I buy a preasamble kit from im with your code in it?
