Old 11-03-2009, 02:45 AM   #12 (permalink)
ATaylorRacing
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
My 98 Neon (SOHC) was rated at 41 mpg and got it while just doing 60 mph! That is the same as todays dumb smart car.
It is a common hot rod trick to cut off half of the water pump fins to free up HP. A less drastic trick on the alternator is to splice a switch into the alternater wiring to disable its function and allow it to free wheel. Many years ago I fabricated an electric water pump on a 2.2 Dodge Omni. I( had removed the water pump entirely and noticed that two of the three bolts had the same spacing as the thermostat housing...so I put one in its place and hooked up radiator hose with an electric water pump called a water guppy that was used to circulate water in a fish holding tank of a boat. That pump came in very handy at the race track to help cool the motor in between rounds on hot days. I broke an alternator belt on the Neon one trip and was amazed by the extra freed up power. You can get under drive pulley kits from a place called Forward Motion. My 305 hp SRT4 Neon gets 40.1 at 55 mph! A different set of 5th gear set ups is being produced for the T-850 SRT4 manual so that 80 mph = only 2300 rpm! Too bad that set wont fit the regular Neons.
38 time NHRA/IHRA drag race champ
05 SRT4 / 12.17@117 mph on DOTs / 33.0 mpg
84 Horizon / 1760 lbs / 24 mpg
95 Neon / 46 mpg
2011 Prius / 62.1 without trying!
