Originally Posted by KJSatz
They will look ridiculous, but when gas costs $4-5/gal in a couple of years I might be able to stomach some pride to save some bank on my 260 mile drives to/from school.
You mean
months, not
years, right?
- deck lid extension or some kind of extension from the trunk
- kammback type extension from the top of my car as far as I can while maintaining rearview vision.
If you make an extension of the top of the roof, then the trunk lid extension won't do much, as the airflow will probably go over it. If I had to pick between the two, I would prefer the Kammy over deck extension for the following reasons:
- It will reduce the size of the wake behind the car,
- It will reduce the vortices caused by the rear pillars,
- It sets the correct angle of airflow with better precision,
- It won't increase the overall length of the car.
As for the tape - I have the same problem. When testing I used whatever I could find in the house, which turned out to be a yellowish-clear packing tape that gets brittle after 2-3 days on the car and leaves a residue that's hard to remove. I'm also looking for something that's strong, but won't leave a goo.
What matters is
where you're going, not
how fast.
Piwoslaw's Peugeot 307sw modding thread
