Old 11-05-2009, 08:45 AM   #8 (permalink)
lunarhighway
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
Where can you buy rubber by the sheet?
you may want to look at stores that sell flooring material, they might have some undersized leftovers of rubber, vinyl or linoleum flooring on discount (especially if they also install the flooring), the material might come with an unatractive patter, but a can of spray paint will render it black. the uglyer the print the cheaper it will be.
i've used linoleum for several small experiments and it takes and keeps paint very well, it's not very stiff, but it stands up quite well, afterall it's flooring so you'd expect it to be able to take some abbuse. friction like direct contact from a tire will grind it away, buy i've actually used it in close proximity with the radiator and that didn't do much.
i've tested a piece with a lighter, it would burn a hole trough it, but the stuff itself didn't really burst into flames or anything wich makes it relatively safe for use on car imho
it came to about 11€ for several sqare meters wich was quite cheap compared to anything else
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
