Old 11-05-2009, 08:56 AM   #1 (permalink)
meelis11
meelis11's Avatar
Green frog - '97 A4 Avant 1.9TDI 81kW
90 day: 46.32 mpg (US)
MPGuino custom characters? Some optimisation suggestions
Hey,
has anybody made custom characters which are more descriptive than "LK" example?
I somewhere saw pictures, where somebody had made custom characters for example "L/100km" - it was made with 2 chars - first char was showing "L\n/1" and second "km\n00" - "\n" means newline - so imagine it as
"L/ km"
" 100"
Would be nice to know how to make them or link where I can get info.
One good hack/optimisation for code also:
I put clear screen commands before every screen change - now that half second when it shows screen name, it is only name - second line is clear. Now you can delete all trailing spaces in screen names and other strings. As a result you should save some bytes (did not count but it was less than before and screen names are clear to read)
inside setup()
Code:
  LCD::LcdCommandWrite(B00000001);  // clear display, set cursor position to zero
  LCD::LcdCommandWrite(B10000);  // set dram to zero
  //LCD::gotoXY(0,0); //no need for it, clear display already made gotoxy(0,0)
  //LCD::print(getStr(PSTR("OpenGauge       ")));
  LCD::print(getStr(PSTR("OpenGauge")));
  //LCD::gotoXY(0,1);
  //LCD::print(getStr(PSTR("  MPGuino  v0.75")));
  LCD::gotoXY(2,1);
  LCD::print(getStr(PSTR("MPGuino  v0.75")));
inside loop()
Code:
   //LCD::gotoXY(0,0); //no need for it, clear display sets it gotoxy(0,0)
   //is any of three buttons is pressed, clear display
   if( !(buttonState&lbuttonBit)  || !(buttonState&mbuttonBit) || !(buttonState&rbuttonBit) ){
   //see if any buttons were pressed, display a brief message if so
   if(!(buttonState&lbuttonBit) && !(buttonState&rbuttonBit)){
      LCD::print(getStr(PSTR("Setup"))); //remove trailing spaces "Setup " -> "Setup"
      initGuino();
   //....code continues
Meelis
