Thread: civic splitter
Old 11-06-2009, 12:55 AM   #25 (permalink)
k.civic.f4i
recession proof rebel
k.civic.f4i's Avatar
man..pstrbrc: you are a scatter brain(not a bad thing). the splitter/ belly pan is what i had in mind from the beginning. the only problem though is that functional splitters are usually made from plywood and usually require additional support.
you might want to make sure that you heat protect the abs plastics because they are known to melt(motorcycle fairings not protected from heat)
