Old 03-11-2008, 11:05 PM   #86 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
Short day at work today So I finished the firewall on the inside. I still have 2 places left to patch then on the engine side of the firewall I need to grind and smooth all the edges. I will use silicon caulk to seal up the gaps to keep rust away then spray it with a good coat of paint.
The other fun thing I did was try and fit the heater core back on the car and it no longer fits So I guess I can either do away with the heat all together or I can use a smaller heater box. I will cut one of the heater boxes I have up and see what I can figure out. I don't really need vents or floor heat, just defroster only would be fine so I might be able to eliminate a huge amount of mess under the dash. I could then use the side vent openings for 2.5" lcd screens for rear view mirrors.
My Convertible Metro XFI Plug in Hybrid Project build log
