Old 11-06-2009, 08:04 AM   #180 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
FYI, I just looked at Nerys metro page Details: Ryo-Oki - 1994 Geo Metro Xfi Fuel Economy - EcoModder.com
he/she does claim to schlep 1300 lbs around (4 people and some gear), so definite kudos for being efficient in that regard (and already owns an xfi).
But it is a good point. Nerys, it would be good to have a baseline though, do you always have 1300lbs of payload? or do you know what average mpg you get with just a driver and no gear? If you are using good technique and can't beat 45mpg in an xfi by a wide margin then you may very well have some mechanical issues.
Originally Posted by Old Mechanic View Post
My Insight shuts off when you are not moving, and uses the battery to boost the engines power on acceleration.
The insight is a good example of a mild hybrid, and has lean burn provisions for cruise. I'm sure the power management could be improved upon with some human intervention though, and a bit of wall plug.
