I should go back and edit my previous post... but Hermie is right about the diffuser, I was talking about the vertical fins on the diffuser, not the actual upward sloping smooth surface. I guess everything I said would still be correct with the exception that you should see some sort of gains from a diffuser, not necessarily the fins.
