Old 03-11-2008, 11:54 PM   #216 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
We ground the splined hub out of our clutch,as you're considering doing, and welded it to one half of a lovejoy type coupler. We welded our stub shaft to the other side of the lovejoy.
If I were doing this all over again, I would consider keeping the clutch and a cut down flywheel. While clutchless shifting isn't impossible, it does grind more in cold weather (a thinner tranny oil might help), and getting in & out of gear frequently (to coast in N, as befits a hypermiler) is easier with a clutch.
But keeping the clutch complicates things because your motor then also has to take a thrust load, which it may not be designed to do.
Because your "stub shaft" doesn't insert as far into your pump motor as ours did, I think you're right to consider setting up some kind of bearing assembly to hold it centered in place.
