Old 11-06-2009, 09:00 PM   #24 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
HOLY COW! Botsapper strikes again with a killer photochop. Thanks!
Originally Posted by Christ View Post
Looks like they found that rear side panel accounts for the largest reduction in drag... I wonder how that scales down to our sizes?
Having seen the pics of 5.0 Junkie's trailer, he's already very low to the ground. Probably not much to be gained, percentage-wise, by adding skirts. The main benefit on tractor trailers is they keep airflow away from the rear wheel truck. Not an issue for Junkie.
Originally Posted by 5.0 Junkie View Post
I was trying to think of a way to put the "wings" on the back of the trailer.
If you're referring to the angled panels on the sides & top of the trailer at the very rear, let's call them a "partial boattail" instead of "wings" - terminology's important!
On the wheels, will just a flat skirt on them suffice, or do I need some moon caps too?
I think a flat panel would be the largest gain. Moonies wouldn't help much if covered. You could also add some material (carved foam) to taper/blend the fender & skirt area backward into the trailer side.
I'm likely going to break down and buy one of the extended height camper shells to help there.
I think that shell is going to help a lot, particularly if you can put a deflector on top, or add a "bubble" to the upper forward face of the trailer (as in Botsappers picture) if you don't.
I noticed the corners from the face to the top & sides are hard. If they were radiused, you'd have cleaner flow along the tops and sides as well.
