Old 11-07-2009, 03:49 PM   #193 (permalink)
tangomar
sukisuki - '00 Grand Vitara 4wd
90 day: 21.88 mpg (US)
Was this thread about burning hydrogen in an Otto cycle engine? And is anyone going to post the scientific data associated with burning hydrogen as a fuel,and the complete energy balance to produce the hydrogen utilizing various technologies?
Bye the way,I've got Zanax if anyone needs one.
There isn't any change in the chemical energy. The energy is there in the gasoline but not used since you have too little time to burn it.
Adding hydrogen (even if small quantities as 1-2 lpm that you can produce with just 10 A -> 130W) increases the flame speed and it allows more fuel to transfer heat to air in the time allowed to produce work (from the spark to the moment where the cilinder speed is faster than the flame front.
The energy balance is almost the same but more heat is transferred rather than been expelled and finish burning in the cat or get recycled.
Just a little bit. Would you dring some water with 1ppm of arsenic? Consider that the maximum quantity allowed in drinking water is 3-20 ug/l...
Some results are summarized in here (sorry for spamming):
http://www.breathablefuel.com/hhopaper.rtf
The Following User Says Thank You to tangomar For This Useful Post:
aerohead (11-11-2009)
