Old 11-07-2009, 05:27 PM   #29 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
Hi Janis! Here's what I ordered so far:
IRAM136-1060B-ND
dsPIC30F2010
7815 voltage regulator (to power the igbt module)
1uF, 0.1uF, (and possibly others, I forgot) MLCC capacitors.
1/3 HP 3 phase AC induction motor. 3450 RPM, 208v/440v.
two 270uF 400v caps for making the DC supply from the house outlet.
Sawickm got me this bugger: PICKIT3. ya!
Here's what I still need:
120v to 120v AC-AC isolation transformer (for testing, so I don't need a bunch of optocouplers)
full bridge rectifier (Ebay has a nice cheap 30amp full bridge rectifier for like $2.50 I think. I'll order that soon)
Encoder ($85... ouch. That's why I want to get the sensorless version to work in the long run). Janis, you are absolutely correct. It would be better to get a resolver for real world driving, but this is just a small test circuit, and the encoder will keep the electronics to a minimum when I'm just trying to get it to work.
2 current sensors. I already have 1 LEM Hass 50-s, but I need one more. That will be another $26. Yuck... The nice thing is, these will be the same current sensors (with a higher amp rating though) for the full sized car version.
I'll add more later if I think of anything.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
