how many times have you had your battery go dead on your car with this system? 50 amps is alot, it's the peek that your alternator is designed to put out leaving nothing for the rest of your car to work on and if you look at the amount of hydrogen that you get out of your system, it's really small.
so with this I suspect you will be replacing your battery at least once per year, your alternator is going to last a few months at best and with the melting wires you might just set your car on fire before anything else.
