Old 11-09-2009, 12:14 AM   #21 (permalink)
jamesqf
Originally Posted by dcb View Post
...with the right engine combo, you should be able to cruise @ 90mpg at 103mph and 180mpg at 52mph?
Well, except for the fact that IIRC the stall speed's about 65 mph :-)
Would narrow wheels and direct drive, instead of wings and a propeller help or hurt mpg?
Some of the mpg improvement probably comes from cruising at higher altitudes* - around 12,000 ft or up to 18,000 with oxygen - where the air is much thinner, so drag is less. I don't know how induced drag from lift would compare to tire drag, but the low frontal area is about the same as the VW 1L car.
* And that's boring. Flying's more fun when you come back with bits of sagebrush in the gear :-)
