Old 11-09-2009, 02:11 AM   #175 (permalink)
JeepNmpg2
Jeep Ecomodder
JeepNmpg2's Avatar
Daddy's Jeep - '00 Cherokee SE
90 day: 19.66 mpg (US)
Mama's Kia - '06 Sedona LX
Reflashing Computer
Originally Posted by sdconcepts View Post
how do you reflash a jeep a computer?
I'm purchasing a UNICHIP setup for my cherokee, and it holds up to five seperate programs (ecu maps, shift points, torque converter lockup, etc). Obviously I'd have one for highway ecomony on 87 octane, one for high horsepower, one for high torque both on 92 octane, one for highway towing, and one bone stock (for emissions purposes).
i'm still debating on which header to get, some say the stainless steel is the way to go but me personally i'm thinking the full length pace setter header is the way to go.
I would highly recomend you go with the set by Doug Thorley. They are extremely well tuned and they are coated so that they push A LOT of heat out of the engine compartment instead of letting it build up from/around the exhaust manifold. Cherokees run hot as it is before any aeromodding that might cut off airflow even more, so any help to rid your engine bay of that destructively high heat is good.
