Waste Oil for FREE Heat
Better yet, use that fuel to heat your business. One of the fascinating things about used oil is that it has the same amount of energy content as it did before it was used, which makes it a great—and cheap!—fuel. Businesses that generate this oil can safely recycle it onsite in the most environmentally friendly manner available with a waste oil furnace or boiler. These complete heating systems provide safe fuel management, EPA-approved used oil disposal and free heat. Emissions are incredibly low and the byproduct is a fine ash that can be thrown away. As if eliminating a heating bill weren’t enough!
All waste oil furnaces are not the same. EnergyLogic systems are the only complete systems that make fuel management, maintenance and ownership simple. They are engineered for extensive use in rugged climates, which means they can withstand any shop environment. They require no daily, weekly or monthly manual adjustments so working them is as simple as setting the thermostat.
