Old 11-09-2009, 10:56 PM   #17 (permalink)
hypermiler01
93 Metro Streamliner
AeroMetro - '93 Metro
There is a lot of taper in the top view, but as I already mentioned, this will be used at fast highway speeds, and other cars have had terrible stability problems with too much vertical taper.
I moved the battery to the rear axle, but I can still pick the rear wheels off the ground with my bare hands.
The tail is almost two feet narrower than the rear fenders.
For sanding, I will be coating it with that glass micro-bubble stuff.
