Old 11-10-2009, 02:14 AM   #14 (permalink)
bgd73
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
perfect alignment is for flat worlds.
I finally got an AWD old sube to negative camber in the rear...its freakin mythological in handling.
I had a delta88 that broke both tail ends of its frame, swayed badly...but never burned the tires again...
A tractor trailer with low air bags..its a hot rod, leaning bouncing and pouncing.
if the world was perfectly aligned, perfect alignment would be perfect.
I learned to call a cars appearance advanced or retarded...cambers and toes and suspension struts back forward or up and down...
This does not need knowledge, but repeating...
