Old 11-10-2009, 07:14 AM   #13 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
Originally Posted by Johnny Mullet View Post
Sometimes those tire shops forget to clean the oxidation from the rim bead seating area. This will cause leaks, lead to underinflation, and eventually a blowout.
The Escort steel wheels these were put on had a certain amount of rust and roughness...decided not to try sanding...since my one experience trying this was not good. I just clean them up using a dish washing scrubber and use NAPAs blue goo when mounting. If I have a bead leak...I can mark the place...break the bead and apply some non hardening gasket goop to that area.
Some use axle grease if they have problems...but if you ever have a tire spin on the rim...you are SOL.
