Originally Posted by mluckham
Agreed that 3 versions is not useful but each has something to contribute ... not just metric, but other additions too? In that light, I will check out the other versions more carefully
This was not meant in negative way
Of course I'm also reading every other source code in hope to find better ideas.
What's your opinion of replacing the hard-to-understand integer math functions with the regular math library?
I'm not shure which "standard 64 bit math" library is meant. Is normal x * z 64 bit in arduino?
But if there is a faster one I would use it, because space is no problem with an ATMega328.
