Front drive cars can run no toe in because the power applied to the front wheels to pull the car makes them toe in. On rear wheel drive cars the drag on the front wheels pulls them towards toe out so if your have static toe in you will have less when you are moving, the amount is determined by the amount of play in your front suspension.
