are you also using the default 500usec Injector Settle Time ?
edit: the 1st 3 tanks i've recorded (if SettleTime==0), i've gotten 213,825, 255,132, and 221,861 ms/gal. All at different gas stations. On the 2nd one, the car & gas tank were significantly cooler than #1 and #3, which were filled up immediately after driving 300+ miles in the heat. Hopefully i dont have to burn 10 tanks to get calibrated.
