My biggest mod is to adjust the "nut behind the wheel". I have a grille block, a Scangauge, more air in the tires, and a battery trickle charger to offset winter headlight usage.
You can also filter the entire garage page like this:
http://ecomodder.com/forum/emgarage....el=civic&year=
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
