Old 11-11-2009, 09:34 PM   #8 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Originally Posted by nvygw171 View Post
As far as bead diameters on cycle tires in realation to car wheels, google "dark side tires". Unless there is some wheel to rim spacer these guy's are running and not mentioning it....
Capri is actually right, to my knowledge, but there are different motorcycle tires that change this. Normally, they shouldn't fit because tires that are designed for tubes don't have as much of a sealing bead on them, IIRC, and that changes the inner diameter of the tire's bead.
I've personally seen motorcycle tires mounted on car rims, and I've personally mounted a car tire on a motorcycle, so I know that it will work.
