Old 11-12-2009, 07:29 PM   #13 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Originally Posted by CapriRacer View Post
Based on what I know about tires, using donuts to improve fuel economy is futile. There is no attempt by the tire manufacturer to control RR - or wear or traction or ride or durability. It's all about cheap. They use substandard materials in these tires because they only need to go 50 miles at 50 mph.
You'd be further ahead (and a whole lot safer) selecting tires where the feature IS RR!
I have a very old set of 12" 125 donuts on the front of my C-car (used to be all 4 wheels), so long as the car is VERY light the tires wear OK but only have as much grip as a half worn summer tread. One tire on the c-car has a weight capacity of about 800lbs more than the entire car weighs.
Donuts do have a very low rolling resistance, at least mine do but that is because they are like driving on a hard rubber tire, the inside including under the tread is 3ply with nylon, with all the air let out the tire doesn't compress very far
