Old 11-13-2009, 12:18 AM   #4 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
I've never had it fail in normal service. I used it for a sign once where it bent a lot with every gust of wind, and it lasted two years, failing just along the crease. Once, I built a whole velomobile body from carefully reinforced light-gauge Coroplast. It was only 15 lbs for a rather large shell, as these things go. I planned it to fail gradually, and separate into parts that could be re-glued. The customer rolled it into a grassy ditch with no damage at all. A folded edge will often be more rugged than a frame and fasteners.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
darcane (11-14-2009)
